Windows App ManagementSolved
7 years ago
We are excited to announce our new add on for Windows devices – App Management.
windows app management
With this now you can easily add store apps to the app inventory and push them to the devices either remotely or via policies.
The best part is that the apps gets installed silently without any user intervention. You can avail this feature on Windows 10 Phones, PC’s and Tablets.
Wanna know more on this. Check out Windows App Management!
What type of apps is supported as of now?
Is it possible to install custom built apps?
Hi Isaac,
Hexnode MDM enables you to easily deploy store apps on your windows device. You can either install apps directly from the Microsoft store or add applications to the app inventory to configure the installation at a later stage (via policies).
You can deploy your custom build MSI apps to windows devices with Hexnode. You can upload your enterprise app with
1) MSI file : upload your MSI file
2) from Manifest URL : input the URL where the app resides
You can install Enterprise app on your device by initiating a remote action to the device(Under Manage tab -> Devices -> select your device -> Actions -> Install Application).
Here’s the help link to add enterprise apps in windows devices.
Lucas Gordon
