Why do i require an EMM?Solved
Why do I need an EMM ? how does it help ?
Enterprise Mobility Management (EMM) is a service that will help an organization to manage and secure the corporate data on the employees’ devices. EMM is the MDM transformed into a more comprehensive solution. Currently, Hexnode supports the management of Apple TV, iOS, Windows, macOS, Fire OS and Android devices.
Using EMM, you will be able to apply configurations and restrictions to devices and also execute actions to remotely lock and wipe them in case they are lost. You will also be able to track the device location and establish separate containers on BYOD devices.
Wanna know more? Check out the blog post on EMM.
