What’s new in Mac?Solved
7 years ago
Smart Card Authentication
Enhance the security of your macOS devices with Hexnode MDM’s Smart Card Authentication.
Now you can enable the use of smart cards for login, screen unlock and authorization.
Check out Mac Smart Card Authentication to know more on this!
Dock
Now you can quickly customize the way your Mac’s dock looks using Hexnode MDM.
Changing the size of the dock, repositioning or hiding the dock, animating the opening applications, enabling magnification and much more can be done at an ease.
Check out Dock to know how this is done!
Login Window Preferences
Customizing Login Window Settings for the macOS devices gets a whole lot easier with Hexnode MDM.
You can now choose the options to be displayed in the Login Window. It also allows you to disable certain options while the user is logged in.
Learn more on Login Window.
CardDAV
Users can sync contact data from the server to their Mac using Hexnode MDM.
You can now allow the users to access and share contacts on a server.
Check out CardDAV for macOS devices to know more.
OS Update
Are you looking forward to quickly upgrading your Mac to the latest available OS version? We got it covered.
Now you can notify about the updates available, download / install / download and install the available updates at an ease.
Better yet, you can enforce OS updates both via actions and through policy.
Check out macOS Update.
macOS Restrictions
We are excited to announce that we have two new key features to the macOS restrictions. This includes the options to Ask for password when removing policy under Basic Restrictions and the option for App Installation from Mac App Store / Mac App Store and identified developers under Advanced Restrictions – Apply with one click right from the console!
what's new in mac?
Learn more.
what's new in mac?
Learn more.
