VPP app updation using HexnodeSolved
Hi, How can I update an app that is on a particular device?
the app is a VPP apple app
To update the VPP app, you can create a Mandatory app policy with the desired apps and deploy it to the devices. Please follow the below steps:
  • Navigate to Policies-> iOS-> Mandatory Apps and add the desired VPP apps.
  • Associate targets and save the policy.
The app will now get automatically updated. In the case of Supervised devices, this will happen silently. If the devices are not supervised, a prompt will appear on the device screen.
