System Agent AppsSolved
7 years ago
Now you can get the latest Hexnode MDM app updates the moment they are released, even with all the system privileges.
Introducing the Hexnode System Agent App for granting system permissions to apps on the go.
With the new Agent App signed and deployed by your OEM vendor, you no longer have to manually download and re-sign every new Hexnode MDM app version. You’ll be able to get all the latest Hexnode MDM updates directly from Play Store.
The Agent App will grant the necessary system permissions to Hexnode MDM as the new versions are installed. Granting system permissions ensures you can use all the advanced MDM features like removing pre-installed apps which are not available natively on Android.
Have a look at System Agent App!
What are the privileges we get on using this app?
The following are the privileges offered by the System Agent App:
  1. Silent app installation- The app will get installed on the devices without showing any prompts.
  2. App uninstallation- System agent app will enable you to remove the apps from the device if you no longer desire the app to be present on the device.
  3. The remote reboot action can be carried out.
  4. The device can be remotely turned off using the System agent app. The work that the user is on will be lost.
  5. Can remotely update the OS on Android 5.0+ devices using the Hexnode System Agent app.
Here is the help link with more info!
