Setup Assistant and Screensaver for MacSolved
Setup Assistant for Mac
Wanna skip the unwanted steps while setting up the Mac for the first time? We got it covered.
The best part is that, it lets you to skip the unnecessary steps and keep only the required steps while setting up the Mac for the first time.
Setup Screen of Mac
Check out Setup Assistant for Mac to know how it’s done.
Screensaver for Mac
Setting up screensaver for your macOS devices got a lot easier with Hexnode MDM.
Introducing Hexnode MDM’s Screensaver for macOS devices. This feature allows you to setup screensaver for your Mac.
Screensaver for Mac
Check out Screensaver for Mac.
