I need to send a file to iOS devices
send files to ios devicesSolved
We currently do not have a feature to send files to iOS devices at present.
However, the feature is on our roadmap. Will keep you posted regarding the updates.
You can find our latest releases, here.
I have got samsung phones… so is that possible?
Yes, you can send any files to enrolled Android devices using the File Management feature. You can also specify where the file should be stored. The file will then get automatically downloaded to the device, from the server, without any user interaction.
Please follow the below steps for distributing the files:
- Navigate to Admin-> File Management and upload the file to be distributed.
- Go to Policies-> Android-> File Management and click Configure.
- Enter the location to save the file and the file name to be sent. Choose the desired file.
- Click on Add.
- Associate targets and save the policy. The file will now be pushed to the devices.
Kindly refer the help doc on transferring the files to devices for more info.
