Send contacts to androidSolved
Is it possible to send contacts to Android devices using hexnode?
Replies (6)
Hi Feline,
Thanks for posting the question.
Hexnode MDM enables you to import contacts to a device and update the contacts whenever needed.
The contacts are exported from a device in the form of a VCF file and the contacts are imported to the device using this file.
Please follow the below steps for generating a VCF file:
1. Open the contacts app on the device and hit the menu button. A pop-up jumps up. Choose the export option.
2. Confirm the export command to initiate the export. A notification specifies the completion of the action. After exporting the contacts, move the VCF file to the system.
Importing the contacts to the device:
1.Login to the Hexnode portal
2. Go to Manage–>Users
3. Choose a device from the list of devices.
4. Go to Actions and select Import contacts to device.
5. Upload the VCF file generated and click on Import.
6. You can also delete the existing contacts before importing the newer ones by enabling the Delete existing contacts option.
The contacts will now be successfully imported to the target device.
Please use the link for a further reference
  • This reply was modified 5 years, 7 months ago by  Grace Baker.
Is this available on enterprise plan?
Hey, Thanks for reaching out.
Yes, “Import contacts” feature is available under plan Enterprise“.
Please us the link to compare various plans and available features under each.
Is it possible to add new contact regarding Android devices using Hexnode?
Yes, you will be able to add new contacts to existing contact records using Hexnode MDM:
  • Add the new desired contact to the device.
  • Open the Contacts app, hit on the menu button and click on Export option.
  • Move the VCF file to the system.
  • Go to the Manage tab in Hexnode portal. Select the desired devices, click on the Actions button and choose Import contacts to device option.
  • Upload the VCF file and click Import.
Please check out our help doc on adding new contacts for more info.
Thanks for the instruction..
