Script to remove an application in macSolved
Hey, is it possible to remove certain applications using scripts?
You certainly can. You can use the custom scripts Action from inside the Manage tab.
Okay. But can someone like provide a script so that I can use it to run it on the device?
Hey Aaron,
You can run any custom script on your Mac using Hexnode’s Custom Scripts feature. Here’s the script to uninstall applications on your macOS devices. You can also check out our Sample Script Repository which contains sample scripts for both Windows and macOS devices.
Hope this clears your query.
Chris Coleman
Thanks Chris. The repository has given me a lot of useful scripts.
Hi…..Applications in macOS are for the most part independent and dwell in/Applications envelope. There are exemptions for this and those sort of applications have a uninstaller script that you can run. There are inclination records, for the application, that can live in the ~/Library/Application Support and ~/Library/Preferences organizers.
