Restrict iOS screen timeSolved
Guys, is it possible to restrict users from altering the Screen Time settings in their iOS devices?
Yes, I believe you can do this from the Restrictions section inside Policies.
In the Advanced Restrictions section for iOS devices inside Policies, you can actually find an option called “Modify Restrictions/Screen Time”. That should do the trick for you.
Hey Whittaker,
Hexnode UEM does provide you with an option to restrict the users from altering the “Screen Time” setting in their iOS devices. As Pseudo_3 has mentioned in the earlier thread, you can navigate to Policies > iOS > Advanced Restrictions and uncheck the “Modify Restrictions/Screen Time” option. This will disable the Screen Time setting on iOS devices and prevent users from enabling it again.
Hope this clears your query.
Chris Coleman
Thank you Hayden and Chris for the timely reply. Bye!
