Remove catalog without apps being uninstalledSolved
Is there any way to remove an app from the catalog without uninstalling it from those devices that have it installed?
The app won’t get uninstalled from the devices even if you remove the app from the App Catalog in your Hexnode MDM console.
To remove the app from the catalog, please follow the below steps:
  1. Go to Apps–>App catalog.
  2. Click on the desired catalog.
  3. Select the App to be removed.
  4. Click on the remove button.
Use the below screenshot for a reference:
app catalog
You can open the Hexnode MDM app and check the Catalog to ensure that the app has been removed.
