Remotely enforce OS Updates on Apple TVsSolved
The current scenario poses a tricky question to businesses about what to do when your OS becomes obsolete. Checking out each device manually for updates would be a troublesome task to deal with. A better solution is to remotely send updates to all the devices.
So here we roll out a pretty new feature that allows you to remotely enforce OS updates on Apple TVs.
Hexnode provides you with two options. Either you can download the updates alone, or you can download and install the updates.
Here’s how you can enforce OS updates.
  • On your Hexnode MDM console, navigate to Manage > Devices > choose the devices on which OS updates should be enforced.
  • From Actions, choose OS Update.
This feature works only on supervised Apple TVs running tvOS 12 or later.
Enforcing OS Update on Apple TV
Have a look at Enforcing OS updates on Apple TVs to know more.
