Push password/PIN to device via policySolved
Is it possible to create a policy to push down a pin/password onto a device?
You can push password restrictions on to the devices using Hexnode MDM.
Please navigate to iOS/Android/Windows/macOS–> Passcode.
You will have the options to configure the passcode rule. In case of Android devices enrolled as a profile owner, you can create the passcode rule only for the Work Profile. Click here to know more about configuring the password rule on Android devices.
We currently do not have a feature to enforce a password onto the devices.
