Push different files to Android devicesSolved
hi, i have used Android File Management to place a file on the device in Single-App Kiosk Lockdown. That works fine to provide the *same data* to all my devices. Is there a way to provide device-specific data?
Hi Kelly,
Thanks for posting the query.
If you want to push different files to specific devices, you will have to configure separate policies to each of them and push them to the concerned devices.
Please use the link to know more about transferring files to devices using Hexnode MDM.
