bitlocker policy error in portalSolved
hi there, I am new to Hexnode UEM and need some help… tried associating Bitlocker encryption policy on several windows devices. Received error
“Unable to turn on BitLocker as the system cannot find the file specified. Resetting the REAgent.xml file may help in resolving the issue.
Is this a windows version issue? How do I solve this?…
This does not seem to be a version issue… Have you tried turning it on manually?
turned on BitLocker on device. Received a similar error “System cannot find the file specified.”
Hi @Nathan !
Thank you for choosing Hexnode UEM!
This is a common BitLocker association issue. To resolve this, reset the REAgent.xml file on the device.
  • Find the REAgent.xml file in C:\Windows\System32\Recovery.
  • Right-click on it and rename the file to REAgent.old
  • Accept the prompt you receive.
  • Reassociate the BitLocker policy with the device after renaming the file.
Please refer to our BitLocker troubleshooting guide to quickly resolve similar issues.
You can learn more on how to manage BitLocker from our help doc.
Hope this answer helps you.
Ethan Miller
  • This reply was modified 3 years, 6 months ago by  Ethan Miller.
