Hey @whittaker, thanks for reaching out to us.
There are different methods through which you can open the links from an app in a particular browser.
You can force the links to open only via Safari using the Whitelist feature. Navigate to Policies > iOS > Blacklist/Whitelist and choose the filter type as Whitelist. Add all the required apps, including Safari. This will restrict the users from accessing your links via other third-party browsers.
Another workaround would be to lock down your devices in multi-app kiosk mode by adding all the required apps and Safari. This way, the website links on your company app will only be opened on Safari.
Make sure you add only Safari as the browser app in both of the above methods.
Chris Wheeler
This reply was modified 3 years, 6 months ago by
Chris.
Chris.
Chris.
