Open command prompt console on hexnode cloudSolved
2 years ago
We need a function to start the comand prompt from the hexnode portal. Writing script and uploading is a look process. Also sending scripts dont always work for reason unknown. I have reported several times that some scripts are stuck on pending. Being able to open the cmd console can resolve alot of issue faster. Current logon username are not listed from what I can see.
2 years ago
Hello @tom-vierth,
We’re glad you reached out to us. We will take up this requirement with the corresponding teams and let you know the possibility of its execution at the earliest.
In the meanwhile, if you could elaborate on the issues you’re facing with executing scripts, we’ll try our best to sort it out for you.
