Not able to push enterprise apps to Windows devices using HexnodeSolved
On trying to deploy apps to windows devices, it fails. What could be the reason?
Could you please specify the kind of apps you are trying to deploy? Are these MSI apps?
I have MSI apps and also app that is not from windows store. Is that the reason?
Non-Windows store apps are not supported on Windows 10 S. All MSI apps are supported on devices with Windows version 1607 and above.
Kindly check out our troubleshooting doc on Windows app installation for more info.
