Mobile Data ManagementSolved
7 years ago
Hexnode MDM has incorporated Mobile Data Management functionality in it to enable organizations to track mobile data usages and monitor them via policies on each of its enrolled devices.
· Track Mobile Data Usage
-Track data usage of all managed devices.
-Track data usage of individual apps on devices.
· Manage Cellular Data Usage via Policies.
-Enforce policies on devices by restricting daily/monthly Wi-Fi, mobile and total data usage.
· Data Usage Alerts
-Alerts via email when data limit exceeds.
-Schedule daily and monthly alerts via email.
· Generate Reports
-App-wise data usage reports
-Mobile data, Wi-Fi and total data usages.
7 years ago
Any ETA on when this will be available for iOS?
7 years ago
Hi Michael,
We don’t have an ETA from the team behind it yet but from their last update, we’d say it would take 2 months to release this feature for iOS devices.
Is that available for iOS now?
For iOS devices, we have Network Usage rules. It lets you control the cellular data usage or roaming data usage by managed apps. Managed applications are those apps pushed to the devices from the portal.
Please follow the below steps for configuring Network Usage Rules:
  • Login to the portal and navigate to iOS-> Expense Management-> Network Usage Rules.
  • Click Configure. Click on +New network usage rule.
  • You will be able to see the following options:
    Cellular data usage: Disable to block mobile data usage by managed apps.
    Data usage on roaming: Disable to block mobile data usage while roaming by the   managed apps.
    Disable the options based on your requirements.
  • Select the desired apps on which the restriction is to be applied from the configuration window. Click Add.
  • Associate targets and save the policy.
Wanna know more? Check out the iOS network usage rules.
