MDM to deploy apps, sync AD and configure VPNSolved
We are looking for an MDM solution for our healthcare institution for the purpose of deploying business and clinical applications for business owned and BYOD devices. Needs to be able to sync with Active Directory. Push VPN policies
Hi Tadgh,
With Hexnode, you would be able to seamlessly integrate multiple Active Directory and Azure AD domains for syncing the users and user groups in order to use them for enrollment and policy association.
Check out the link to know how you can integrate Microsoft Active Directory with Hexnode: https://www.hexnode.com/mobile-device-management/help/microsoft-active-directory-integration-with-hexnode-mdm/
To know more on the integration of Azure AD with Hexnode, check out Azure AD integration with Hexnode
A Virtual Private Network (VPN) improves security by redirecting network traffic via a virtual network. Hexnode enables you to push VPN policies to the enrolled iOS, Android, and macOS devices. Refer the help links to know how you can achieve this:
iOS: https://www.hexnode.com/mobile-device-management/help/ios-vpn-settings/
Android: https://www.hexnode.com/mobile-device-management/help/how-to-configure-vpn-settings-on-android-devices-using-hexnode-mdm/
*In the case of Android, VPN policies works only for Samsung Knox devices
macOS: https://www.hexnode.com/mobile-device-management/help/configure-vpn-on-macos-using-hexnode-mdm/
To explore all the above features and much more, sign up for our 30-day free trial from here.
Cheers,
Eva Tyler
