Location Grouping via APISolved
I have devices in certain cities around my region. How can I retrieve the details of which device is in which city via Hexnode API?
Hi Kayle,
In your Hexnode account, you can create various geofences, which can be treated as the boundaries of the cities your devices are currently located in:
Once the Geofences are created, you can create a Dynamic Device Group on your Hexnode portal, which shall group the devices based on the Geofence they are currently located inside:
Finally, Hexnode shall be able to retrieve the device group details of the device via API.
Thomas Specter
