Installing Calendar app without app storeSolved
Hey folks, need your help. Here’s the situation- one of the employees accidently deleted apple’s calendar app from the device (iOS version 12.3) and there’s no way to install it manually (or so I believe) because we have blocked app store on all the devices. Can we install it via the portal??
Try installing it as a VPP app. You can still push vpp apps to the device even if app store is blocked.
Hi @emersyn, thanks for reaching out to us.
Interesting situation you’ve got there! VPP apps can still be pushed to the devices even if App Store is blocked on the device end, like @corbyn pointed out. However, built-in apps like the Calendar app won’t be available in the Apple Business/School Manager portal to be pushed as VPP apps. The sensible solution here would be to remove the App Store restriction on that particular device temporarily and then install the Calendar app from the portal before reinstating the App Store restriction again.
To prevent situations like this in the future, navigate to Policies > iOS > Advanced Restrictions > Allow App Settings, uncheck the Remove system apps option and associate the policy with your target devices. This will block users from removing built-in system apps like the Calendar app.
Please note that the Remove system apps option is supported only on supervised iOS 11.0+ devices.
Hope this helps.
Chris Wheeler
Hexnode UEM
Hey Chris, can we also prevent users removing other ios apps this way or is it just applicable to system apps??
@corbyn Yes, there is an option for that too. Navigate to Policies > iOS > Advanced Restrictions > Allow App Settings and uncheck the Remove apps option to prevent users from uninstalling apps from the devices.
Remove apps option under Advanced Restrictions for iOS in the Hexnode portal
This option is supported on supervised devices running iOS 4.2.1+.
Chris Wheeler
Hexnode UEM
