Hi, I have a tablet which I have been using to test an app within Hexnode. I’d like to add two more tablets so that my client can test the app also. Would you mind reminding me how to do this please?
- Home
- App Management
- I have a tablet which I have been using to test an app within Hexnode.
I have a tablet which I have been using to test an app within Hexnode.Solved
8 years ago
Hi, Liam.
Here’s a gist of what you need to do.
- Enroll the two Android tablets
- Create a group and add the devices.
- On your Hexnode MDM portal, upload the Android app APK you want to test.
- Create a policy, set the test app as a mandatory app and assign the policy to the group.
The apps will be automatically pushed to all the devices in the group.
You can add app updates or different apps by editing the policy.
To revisit each step in detail,
- Enroll devices
- You can register the devices easily by scanning a QR code. Follow this set by step guide on QR code enrollment
- Group devices
- You may employ static or dynamic groups. If you have just the three devices, static groups would be fine. If you plan on expanding the test group with a lot more devices, a dynamic group would be the way to go.
- Static groups
Create simple static groups by following this help. - Dynamic groups
Create a dynamic group with various criteria to have new devices automatically grouped.
- Static groups
- Upload Enterprise App
- Hop over to the Android Enterprise apps section on our help to learn how to upload the APK and push it to the devices.
- Set as a Mandatory app
- Here is how you can set the App as a mandatory app
This reply was modified 7 years, 10 months ago by
Hexnode Support.
Is there any automated process for the devices to get added automatically?
Yes, there is. You can create a dynamic group. The devices will get automatically added to the group based on the filters that you have configured. For example, you can group devices based on its serial number, UDID, IMEI number, etc. The devices will be added or removed from the group during the periodic group sync.
Please follow the below steps for the creation of dynamic groups:
- Navigate to Manage-> Device Groups and click on New Dynamic Group.
- Enter a Group Name and Description.
- Under Condition filters, you can add filters and choose whether all these have to be met or just any one of them.
- Under Location Filters, you can select locations to group the devices based on regions.
- Click on the Preview button to view the devices that meet the condition and click on Save.
Need more info? Check out Dynamic Device Groups in Hexnode MDM.
Leaderboard
2788 pts
574 pts
275 pts
266 pts
225 pts
