how to see recent apps in kioskSolved
i just had an issue on the multiple tabs. normally when you are on an app, you can press thr square button on android and check your other tabs.
however, although the multiple tabs do show but they flicker away in 1 second.
Hope you are referring to the recent apps button. The recent apps button is disabled by default in the kiosk mode.
To enable the button, please navigate to Policies-> Kiosk Lockdown-> Android Kiosk Lockdown-> Peripheral Settings-> Hardware/Software buttons and enable the option ‘Enable recent apps button’. Please note to associate targets and save the policy.
Kindly use the link for more insights into Peripheral Settings.
