Hiding profile pane on macOS devicesSolved
2 years ago
Hi, I have disabled the Profiles pane on my Mac by executing a script that uses the com.apple.systempreferences payload type. I was wondering if the Profiles pane will stay disabled even when I update my OS to Ventura.
2 years ago
I updated my mac to Ventura, and there seem to be a lot of differences. Many panes under system settings show behavior that I’m not used to.
2 years ago
Hello, welcome to Hexnode Community!
One of the significant changes that Apple has brought about in its new OS version, Ventura, is the deprecation of the SystemPreferences payload. System Preferences has now been replaced with the newly introduced System Settings, and the DisabledSystemSettings key controls the various panes within it.
The script you used will not be effective once you update your system OS to Ventura, as it uses a deprecated payload.
Moreover, the Profiles pane is not listed under the new DisabledSystemSettings key, so it can’t be disabled at all in the new OS version.
https://developer.apple.com/documentation/devicemanagement/systempreferences
@schyler-scott, before updating the OS, you could go through the new features and
changes
introduced so you’re confident with the new OS version.
Hope this helps. Do get back to us in case of any further queries.
Chloe Edison,
2 years ago
Yeah, I don’t think the Profiles pane can be disabled in Ventura. Apparently, System Settings extensions within the Privacy & Security section cannot be disabled and Profiles comes under the Privacy & Security section in System Settings.
https://github.com/apple/device-management/blob/0340fd30e0bf820ded4797aa658a3ba8b6ab6c6e/mdm/profiles/com.apple.systempreferences.yaml
