Group devices based on missing app countSolved
Hi Team,
Can I group devices based on missing app count? I need a set A, where the missing app count is 5 and below. I need another set B, where the missing app count is 10.
Thank You!
Yes, you can create two dynamic groups, one with devices whose missing app count is 5 and other with devices whose missing app count is 10. Follow the below steps for the same:
  1. Navigate to Manage tab-> Device Groups> New Dynamic Device Group.
  2. Add group name and description.
  3. Below Condition filters, you will have the option to create the criteria based on which the dynamic group is created.
  4. Select Compliance info as Column group and Missing apps count as Column.
  5. Choose Equal to as the comparator and then set the value of filter. Set the value as 5 while creating the first group and as 10 while creating the second.
  6. Click on Preview button to see the list of devices that meets the criteria.
  7. Click on Save group to save the details of the group.
Check out the help doc on Dynamic device groups for more info.
