Is it possible to check what files are being downloaded and stored on a remote employee device?
- Home
- Content Management
- Find the files that are being downloaded to Android devices using Hexnode
Find the files that are being downloaded to Android devices using HexnodeSolved
Tags
Could you please tell me the device platform?
The devices are Android.
Thanks for the reply.
Hexnode enables you to access and manage the files and folders on enrolled Android devices.
You can move, delete and copy the files on the Android devices:
- Navigate to Manage-> Devices and click on the desired device.
- Go to File Explorer sub-tab and click on Open File Explorer.
- The list of files and folders on the device will be shown.
- Click on the Actions button and choose Move/Copy/Delete, based on your requirement.
- If Move/Copy is chosen, a pop-up will show the available folders and sub-folders. You can also create a new folder by clicking on the Add New Folder. If Delete is chosen, a pop-up will appear asking for confirmation.
Please check out our help doc on file explorer for more info.
Leaderboard
2788 pts
574 pts
275 pts
266 pts
225 pts
