Export location history detailsSolved
Can I export the location details of my user’s devices in pdf format?
Hey, Thanks for posting.
Hexnode lets you export the location history of devices as CSV files.
For this, login to the Hexnode console and go to the Manage tab. Identify and click on the desired device name, which will direct you to the corresponding device summary page. Navigate to the Location History and click on the Download button on the top right corner of the Location History section.
Kindly use the help link for the detailed explanation of the same.
