enable location check-in while in kiosk modeSolved
7 years ago
I need help. I’m in kiosk mode and I want to enable Location check-in. How do I do this?
7 years ago
Tamara, here’s how you do it.
Enable Location Check-in option: To enable users to check in their location, Go to Policies tab and open your kiosk policy. Click on Kiosk Settings tab. Enable the option “Enable User location check-in” under Miscellaneous Settings.  Save your policy.
Location Check In
Use Location Check-in option: Tap on the Settings icon on your device and select Location Check-in option. This will open a prompt asking you to enter location notes. Once entered, click Send.
Location check-in
View Location Notes: You can find the history of location notes sent by the users from Reports > Location Reports > Location History.
Here is all you need to know about location tracking.
Where can I find this option now?
There are some changes due to the recent updates. To enable the Location Check-in in Android Kiosk, please navigate to Policies-> Kiosk Lockdown-> Android Kiosk Lockdown-> Peripheral Settings-> Location and enable the option Users can add location notes. Associate targets and save the policy.
Screenshot 2020-03-05 at 6.17.35 PM
Once the kiosk mode is enabled on the device, open the settings app on the device. Tap on the Location Check-in pop-up that appears on the device screen. A prompt appears to enter the location note. Click Send.
Screenshot 2020-03-05 at 6.18.36 PM
To see the location notes from the Hexnode MDM console, please navigate to Reports-> Location Reports-> Location History.
Need more help? Check out Location Check-in on Android.
