Does remote-wiping an iOS device delete the eSIM?Solved
2 years ago
Subject says it all, I think. Does remote-wiping an iOS device delete the eSIM profile, or keep it? I have some iPhone SEs with eSIM only (no physical SIM), and I don’t see an option in the portal wipe dialog to select keep/delete.
Thanks!
2 years ago
Hey @brobi, thank you for reaching out to us.
A remote wipe would completely remove all data and configurations on your iOS device including your eSIM profile.
Hope that clears things up for you!
