does every device need to be associated with an email address?Solved
8 years ago
8 years ago
Hi there,
No it is not mandatory that every device should have a separate user/email address. You can associate as many devices to a user, and there is no limit on that.
You can disable the authentication in Enrollment, this will assign the devices to the default user selected in the Enrollment Settings(Admin Tab->Enrollment Settings).
Here is the screencast to enable/disable the authentication in Enrollment.
How_To_Enable_Authentication_In_Enrollment
It seems that the options in the video looks slightly different from the portal?
This is due to some recent updates that we have made. Please use the updated screencast below for reference.
