display company logo in kioskSolved
My company mostly runs on android in kiosk state with very few apps in it. Is there any way to display my company logo on all my devices while in kiosk… can someone help me out
@piper try setting a wallpaper with your company logo. Probably this wallpaper will be the same in the kiosk.
Hey @piper
What @lydia suggested is a good way to display your company logo in Kiosk mode.
Another approach is to set up screensavers for your Android kiosks with images, videos, and even custom background music. To access this feature, head over to Policies > New Policy or edit an existing policy > Kiosk Lockdown > Android Kiosk Lockdown > Kiosk Screensaver.
Tick the Enable Screensaver checkbox and add your preferred images and videos. Next, enable the Play custom background music option under the Audio section and choose More Music from the dropdown menu to upload custom music files. Under the Display section, configure the display settings to customize the screen orientation of the device and set the brightness level according to your requirement. Now, select the target devices and associate the policy.
Hope this helps your query.
Johan Blake
Hexnode UEM
