Disabling Factory Reset ProtectionSolved
Hello.
Can the factory reset protection in Android be disabled from the portal? One of our employees has left the company and I need to reset the device. But since FRP is enabled, I am afraid we won’t be able to use the device again.
Hi there, @Boaz! Thanks for reaching out to us.
No worries, you can disable FRP from Hexnode portal! Under Policies tab, choose an existing/new policy, navigate to Android, and select Advanced Restrictions. When you scroll down, you can see Factory Reset Protection at the end of the page. From the dropdown list, choose Disable Factory Reset Protection. Now, you will be able to reset and use the device without the Google password.
Hope that answers your query.
Gabriel Galbraith
Hexnode UEM
  • This reply was modified 4 years, 3 months ago by  Gabriel Galbraith.
  • This reply was modified 4 years, 3 months ago by  Michelle.
so what about the bypass feature? what does that do?
Thank you for reaching out, @Kardal!
The Bypass Factory Reset Protection feature enables you to log in to a device locked in factory reset protection mode. This can be done by entering a G-Suite or Google Account ID instead of Google account verification. This will help you in scenarios where you don’t know the previously configured Google account credentials.
Hope that helps.
Gabriel Galbraith
Hexnode UEM
