Is there any way to delete VPP apps from Hexnode. Few apps added in ABM are not needed now. But since I have synced it with Hexnode, they are still being shown in Hexnode.
- Home
- App Management
- Delete VPP Apps
Delete VPP AppsSolved
Remember seeing a delete button in the app section. That won’t work?
Hello sysadminatsolutions and cad_e,
Using the delete button in the App section will only make the VPP apps disappear momentarily. Once the VPP account syncs with the portal, the apps will reappear. Here is a workaround to hide unwanted apps:
- Make sure that the unwanted VPP apps are not associated with any user or device in Hexnode.
- Create a dummy location in Apple Business Manager.
- Transfer the undesired apps from your account to this new location.
- Open the Hexnode portal and go to Admin > Apple Business/School Manager > Apple VPP. Delete the account and create it again by giving a name and uploading the VPP file token. To download the VPP file token, go to Apple Business/School Manager > Settings > Apps and Books > download the token of the required account.
You will no longer see the undesired apps.
Hope that helps.
Cheers!!
Deborah Timothy
“Delete the account and create it again by giving a name and uploading the VPP file token” can the same name be used?
@sysadminatsolutions Yes. You can use the name of your deleted account for your new account.
Cheers!!
Deborah Timothy
Leaderboard
2788 pts
574 pts
275 pts
266 pts
225 pts
