How to customize an app catalog in Hexnode?Solved
I was trying to create policy for my Android phones, with app catalogs. However, when I click on Add catalogs, few catalogs appears. Can I customize one of my choice?
You can customize a new App Catalog with desired apps.
Please follow the below steps for the same:
  1. Login to your portal and navigate to the Apps tab.
  2. Click on ‘App Catalogs’
  3. Click on ‘+ New’. Give a suitable name and description.
  4. Click on Apps > +Add Apps to add apps and on Groups > +Add App Groups to add App Groups, to the App Catalog.
  5. Save the Catalog.
The new catalog will now appear in the list while configuring a policy.
Kindly use the link for a reference.
