create app categoriesSolved
Hi,
We’ve added some apps to the hexnode apps section. However, there was no suitable category for the collection of apps, so we assigned a category at random. We are now having difficulty discovering some uploaded apps. Can we create a category to conveniently filter out apps?
Hi @trey,
Thanks for reaching out!
Yes, you can create your own app categories on the Hexnode App repository. To create a category, follow the steps below.
  1. Navigate to the Apps tab on the Hexnode portal.
  2. Click on Apps > +Add Apps > Enterprise App.
  3. Head on to Category, press on ‘+’, give your category name and click on ‘✔’.
A new category with the given name will be created. You can only add enterprise and web apps to this category.
To filter your apps by category, go to the Apps tab and select your category from the drop-down menu under the Filter Apps option.
Hope this helps your query.
Evin Lee
