Copy code testingSolved
11 months ago
Creating (Declaring) PHP Variables
In PHP, a variable starts with the $ sign, followed by the name of the variable:
In the example above, the variable $x will hold the value 5, and the variable $y will hold the value “John”.
Note: When you assign a text value to a variable, put quotes around the value.
Note: Unlike other programming languages, PHP has no command for declaring a variable. It is created the moment you first assign a value to it.
PHP – Using Iterables
The iterable keyword can be used as a data type of a function argument or as the return type of a function:
