Choose the location of the app storeSolved
8 years ago
Hi, is it possible to choose the location of the app store? I want to install app from french App Store
8 years ago
Hi Ryan,
You can select the location of the App Store from the Admin tab in Hexnode MDM console.
  1. Go to Admin -> App Settings -> + Add Apps -> Store App.
  2. Select the platform and search for an app. Leave the search field blank if you have nothing specific to search.
  3. From the top-right corner of the app search dialog, select France.
This will show apps from French App Store. Select and add all required apps to the app list. I am adding two links which will show app installation in detail.
iOS app distribution with Hexnode MDM
Install Android app remotely with MDM
french
Is the App settings changed? I can’t find this on my portal ?
This is due to some recent updates that we have made in the portal. Please navigate to Apps-> +Add Apps-> Store Apps and search for the desired app. On the windows that appears, you will find the option to choose the desired country from the drop-down list at the top right corner.
Please use the below updated screencast for a reference:
