Can i set the ringtone on the user devices?Solved
I don’t want employees using the mobiles setting ringtones as per their wish. Can I decide the ringtone on the phone without setting manually setting on each of the device.
Could you please specify the device platform?
The devices are Android
Hey, Thanks for the reply.
Hexnode can let you configure ringtone on Android devices without having physical access to them.
To set the ringtone on Android devices:
  1. Navigate to Manage-> Devices and select the desired devices.
  2. Click on Actions and choose Change Ringtone.
  3. Click on Choose file and select an mp3 file with a size less than 350 KB.
  4. Click Done.
Check out our help doc on setting ringtone on Android devices for more info.
