Calendly.com -> Hexnode BrowserSolved
Hi,
I have allowed a particular site through the application settings for the Hexnode Kiosk Browser. On one of the subsites there is a scheduling system where you can book an appointment/meeting. This system uses Calendly.
I have added calendly.com and a whole bunch of sites to the allow list, but I couldn’t get it to work. I even removed the [“*”] from the block list on a test device, and it still won’t work.
The website loads and all, just the section on the site is blank where the calender/schedule/appointment thing sits.
I have also tried allowing javascript and allowing all popups, but still no luck.
Anyone have any ideas?
Hi Justin, welcome to Hexnode Community!
The issue is probably because the calendar/scheduler is loaded from another URL that you may not have whitelisted. Even if the URL is a subdomain of https://calendly.com/, it has to be whitelisted separately.
Please give it a try and let us know.
Chloe Edison,
2 years ago
Thanks for the reply Chloe.
I had cleared any blacklists and whitelisted [“*”] but didn’t get anywhere.
I did however add [“*”] to the allow cookies from these sites field. It now works on my test device, hopefully soon we will see if it works with the user devices.
Cheers
Justin
