Add Wi-Fi to QR code for Android Enterprise Device Owner Enrollment, and moreSolved
1. Add Wi-Fi to QR code for Android Enterprise device owner enrollment
With Hexnode, you can now add Wi-Fi configurations to the QR code while enrolling devices in Android Enterprise as device owner.
Here is how you can do this,
  1. Navigate to Enroll > Platform-Specific > Android > Android Enterprise, and enroll your organization.
  2. On completing the registration, a QR code will be generated on your Hexnode portal.
  3. You can configure the Wi-Fi settings for the QR code from QR Code Settings.
2. Automatically power on/off a device when a power cable is connected/detached.
New options to automatically power on/off the devices when a power cable is connected/detached, has been added under Policies > Android > Advanced Restrictions > Allow Settings.
    • Automatically power off a device when USB is detached – Check this option to power off the device when a power cable is disconnected from it. This will not work if the option ‘Power Off’ under Android > Restrictions is disabled.
    • Automatically power on a device when USB is connected – Check this option to automatically turn on the device when a power cable is connected to it.
Before configuring these features, ensure that you have purchased and added the Knox Platform for Enterprise (KPE) premium license key to your Hexnode portal.
